Photo 50708759 © Ganna Todica | Dreamstime.com
Priorities With Blank List On Blackboard Dreamstime Xxl 50708759 5fa1727e44451
How to Prioritize Competing Repairs
Nov. 3, 2020
Knowing which repair can wait and which one can't
You’re the maintenance manager. Three lines are down, but you have only one qualified tech to fix them. If you send the tech to one machine, then the other two must wait.
You could prioritize by who screams the loudest or which equipment has been down the longest. A correct response will be based primarily on the profit ranking of the equipment. This is information you should already have from production. It’s your default prioritization factor, but others can override it:
  • Environment takes precedence over production.
  • Safety takes precedence over anything else.
  • One production department may say they must ship X units today; if so, get concurrence from the plant manager.
  • Aggregate profit protection is a sure thing if taking a lower profit line first. For example, Line A produces $120K/hour and the problem is a 5-min. fix; Line B produces $250K/hr, but the problem is a 3-hr fix. Line A can produce $360K while you are fixing Line B.
Latest from Maintenance, Repair & Operations
ID 104750065 | 3d © Sashkinw | Dreamstime.com
dreamstime_xl_104750065
ID 150805489 © Welcomia | Dreamstime.com
dreamstime_xl_150805489
