When you say something needs to be repaired, does everyone know what you mean? Not necessarily. A repair can mean:
- Just get it running again because we have a deadline to meet.
- Restore it to its previous condition (which might not be adequate for the conditions of use).
- Fix only what’s broken.
- Fix what’s broken and recondition as needed while you’re in there.
- Replace not only the bad part, but also all replaceable parts.
- Restore it to OEM condition.
Which of these is the correct definition? That depends on the equipment, age and condition of replaceable parts, conditions of use, cost analysis, available time, available parts, and many other factors. With so many dynamics involved, two technicians confronting the same situation will likely apply different definitions. It is possible to have two correct definitions, two incorrect definitions, or one correct and one incorrect definition.
Create a repair decision model that helps technicians avoid using an incorrect definition and train them in its use.
Mark LamendolaMark Lamendola
