© Milkos | Dreamstime.com
Maintenance Resources Might Not Be as Limited as You Think
May 19, 2020
Sometimes, corporate executives who cannot tell a wire stripper from pump pliers publicly refer to maintenance as a “necessary evil.” They put less emphasis on the first part of that than they should. Consequently, maintenance budgets are often the first ones cut.
Ask 100 maintenance managers if they are working with overly tight limits on resources, and 98 of them will probably say yes.
That view of resources from the company is often correct. If you are resource-constrained, however, to what degree to you tap the vast resources available outside of your company? Consider these free ones:
- Manufacturer websites. You can often find updates to recommended practices, maintenance guidance, and information on upgrading equipment to reduce required maintenance.
- Webinars. These are often hosted by industry organizations and/or trade publications or trade organizations, so the focus is on usefulness to the attendees.
- Trade publications. In addition to print, they have websites, newsletters, and podcasts that provide useful insight.
