© Boris15 | Dreamstime.com
Maintenance Word Collage 5e9e2d32c194c
Unscheduled Should Not Mean Unplanned
April 21, 2020
Tips for reducing time spent on unexpected repairs
The idea that a scheduled repair should be planned seems obvious. Why would you schedule it and not plan it? However, when something unexpectedly breaks, the general expectation is that maintenance is going to fix it immediately. This would seem to leave no time for planning.
Things are not always as they seem. The planning takes place long before the breakage occurs. If that planning is done well, repair time can be decreased significantly.
Here are some tips:
  • Identify the most likely failure modes for each piece of equipment. Write a troubleshooting and repair plan for each one.
  • If a given repair is complicated, make a how-to video and add a QR code to the repair procedure.
  • For each piece of critical equipment, train and “certify” select individuals to perform repairs on that equipment. Ideally, each maintenance person will have a few different certifications and there will be plenty of overlap.
  • For each piece of critical equipment, permanently set up task lighting that can be turned on when needed for repairs.
