anyaberkut/iStock/Getty Images Plus
Interpreting Feedback
Dec. 3, 2019
Why you should always clarify feedback before taking action
Suppose at a maintenance meeting, the electricians say the digital multimeters (DMMs) they use are outdated and not adequate for the work they perform. The plant engineer says, “We'll get you new ones.”
The electricians leave the meeting believing management will follow up to find out specifically which features they need. A week later, however, each electrician receives a new DMM chosen by someone in the purchasing department. The new DMMs don't provide what the electricians need.
What went wrong? Management “interpreted” the feedback instead of clarifying it. Consequently, their implementation did not address the issues underlying the feedback.
Instead of interpreting, clarify:
  • Ask for specifics. “Do you need one you can use for VFDs?”
  • Expand on specifics. “Would you need the same DMM to also have a temperature probe, or would that be an additional meter?
  • State exclusions. “Would that exclude thermal imaging? What about a temperature probe?”
  • Ask about underlying issues. “What problems are you having due to outdated DMMs?
Latest from Maintenance, Repair & Operations
ID 79734135 © Tashatuvango | Dreamstime.com
A folder with a tab that says 'Equipment Maintenance' rests on top of a keyboard.
ID 346742527 © Contributor Asia | Dreamstime.com
Pink blocks that spell 'quiz' against a light green background next to a white alarm clock.
A finger presses a green key on a keyboard that says 'NEC National Electrical Code'
