• Unsafe Conditions Around De-Energized Equipment, Part 1
    Even if equipment has never been energized, you can have an unsafe work condition.
    April 1, 2019
    While lockout/tagout removes a major safety hazard, it doesn’t automatically establish a safe work condition. Even if equipment has never been energized, you can have an unsafe work condition.
    For example, it’s a green construction office project and you’re running the electrical metallic tubing (EMT) to each room for the receptacle boxes you’re also installing. Drywallers are working practically on top of you and there’s another crew installing the lights overhead. Needless to say, it’s crowded, and you have many tripping hazards, such as buckets of drywall compound, extension cords, tools, ladders, and various materials.
    You have an unsafe working condition just because of the crowding and parallel projects. Dangers can be reduced in multiple ways. For example, designate one room for storing tools and materials instead of having them spread everywhere. Run extension cords along walls and tape them in place. Coordinate with other crews so you aren’t working on top of each other.
