If you’ve performed repairs in an industrial setting for even just a short time, you’ve gone the spit and bailing wire route just to get something running again. It’s not a proper repair for some reason (e.g., correct spare part not on hand or the plant expert on this equipment is on vacation). Nonetheless, it’s good enough for the immediate situation and will allow production to get a critical order out the door.
What often happens, however, is the equipment appears as if it “ain’t broke” so “it don’t get fixed.” Maybe production won’t agree to the downtime needed to properly repair it. Or maybe the maintenance system shows the trouble call was answered and the equipment has been repaired. The equipment continues to run until it fails spectacularly.
To prevent temporary repairs from becoming failure time bombs, assign an expiration time to any temporary repair and post that time at the equipment. When that time expires, shut the equipment down. And any time a temporary repair is done, create a work order for the permanent repair that “would have” been done.
