ARISTA®: Built for Commercial and Municipal Projects Big and Small
What does a classroom have in common with a hotel ballroom or retail clothing store? At first glance, not a ton. However, when thinking of these indoor spaces in terms of lighting control needs, they’re more similar than different.
Each project likely has multiple load sources, a need to adjust levels based on ambient lighting, multiple usage scenarios, and a need for occupants to adjust light levels. The main difference is room size.
The expanded ARISTA Advanced Lighting Control System by Intermatic makes it easy for contractors and specifying engineers to create indoor lighting environments for projects of all types and sizes. In addition to the current suite of Room Controllers, Programmable Switches, and Sensors, a handful of new devices give installers even greater flexibility when designing an ARISTA environment.
In the example below, we see how ARISTA can be used to support a 1,200 ft2 classroom that operates Monday through Friday, with planned but varying schedules week to week. By combining a daylight harvesting sensor, multiple controllers, a 4-button programmable switch, and a dual-tech ceiling sensor, the installer is able to maximize natural light while giving occupants flexibility. In this setup, a teacher or student could easily adjust lighting scenes for everyday teaching, audio-visual presentations, and background/safety lighting when class is not in session.
In a much larger retail space (2,500 ft2), similar principles apply. In this ARISTA example, the installer incorporates multiple room controllers to create use-specific lighting scenes, and to accommodate for limited natural light. Moreover, multiple occupancy sensors help facilitate appropriate lighting in limited-use spaces like restrooms and fitting rooms.
Regardless of the size or layout of a given space, ARISTA makes it easy for contractors and electricians to accommodate client needs.
Fixture-Appropriate Controls
In addition to planning for natural lighting and activities within a space, installers should consider the various load types within an indoor environment.
New ALC1-P Phase Dimming Controllers are specifically designed to work with phase-dimming fixtures, such as sconces and track lighting, which allows for greater flexibility when planning new ARISTA projects. The ALC1-P is also compatible with electronic ballast, LED, Tungsten, MLV, and ELV loads.
Occupant-Friendly Programmable Switches
Lastly, a major part of any successful commercial lighting control project is the handoff to occupants once lighting controls are installed and configured.
New ALC-2B-BT (2-button) and ALC-4B-BT (4-button) Programmable switches allow occupants to adjust brightness levels and select lighting scenes with the push of a button. They also include default dimming functionality if a client chooses not to create their own lighting scenes.
Both switches offer a battery-powered option and can be mounted anywhere. This can take away the hassle of running wire for electricians during installation while also ensuring end-users are able to place ARISTA programmable switches where they’re most needed.
Ready to tackle your next commercial lighting control project? Connect with an Intermatic representative today to learn more about the ARISTA Advanced Lighting Control System and get started.
Sponsored by:
