ABC's Construction Backlog Indicator Remains Stable in September
Contractors remain optimistic thanks to data center growth
Oct. 14, 2025
Key Highlights
  • Construction backlog remained unchanged at 8.5 months in September.
  • Infrastructure projects and data centers are key drivers of backlog growth.
  • Construction Confidence Index components for sales, profit margins, and staffing remain above 50, indicating positive growth expectations.
  • Industry challenges include falling employment and decreased construction spending, but contractor confidence remains resilient.
Associated Builders and Contractors reported that its Construction Backlog Indicator remained unchanged at 8.5 months in September, according to an ABC member survey conducted Sept. 22 to Oct. 6. The reading is down 0.1 months since September 2024.
View ABC’s Construction Backlog Indicator and Construction Confidence Index tables for September. View the full Construction Backlog Indicator and Construction Confidence Index data series.
Over the past year, backlog has declined in the commercial and institutional and heavy industrial categories, while it has increased substantially in the infrastructure category.
ABC’s Construction Confidence Index reading for sales declined in September, while the readings for profit margins and staffing both increased. The readings for all three components remain above the threshold of 50, indicating expectations for growth over the next six months.
“Falling industrywide employment, a dearth of job openings, and ongoing decreases in construction spending have not diminished ABC contractor member backlog or confidence,” said ABC Chief Economist Anirban Basu. “This stability primarily stems from two sources. First, public sector activity has held up far better than its private counterpart, and that is supporting elevated backlog in the infrastructure category.
“The second source of industry momentum is, unsurprisingly, data centers,” said Basu. “Approximately 1 in 5 contractors was under contract to work on a data center project in September. While that’s a slightly lower share than in August, contractors that have data center work had significantly higher backlog (12.0 months) than those who did not (8.0 months).”
