State Construction Unemployment Down in 32 States
The not seasonally adjusted national construction unemployment rate dropped 0.6% in December 2022 from a year ago, down from 5% to 4.4%, according to a state-by-state analysis of U.S. Bureau of Labor Statistics data released by Associated Builders and Contractors. Thirty-two states had lower unemployment rates over the same period, Iowa and Missouri were unchanged, and 16 states were higher.
National NSA payroll construction employment was 242,000 higher than in December 2021. From March through December 2022, seasonally adjusted construction employment was above its February 2020 pre-pandemic peak of 7,624,000, except for a slight dip in April. As of December, it was 153,000 greater than its pre-pandemic peak.
Residential construction employment has fully recovered, while nonresidential construction employment is still below its pre-pandemic peak. December SA residential payroll construction employment was 198,000 above its pre-pandemic peak while nonresidential payroll construction employment was 45,000 below its pre-pandemic peak.
In December 2022, 36 states had lower construction unemployment rates and 14 states had higher rates compared to December 2019.
Recent Month-to-Month Fluctuations
National and state unemployment rates are best evaluated on a year-over-year basis because these industry-specific rates are not seasonally adjusted. However, due to the changing impact of COVID-19, high and rising interest rates and other national and international disruptions, month-to-month comparisons offer insight into the rapidly shifting economic environment for construction employment.
In December 2022, nine states had lower estimated construction unemployment rates than in November, 38 states had higher rates and three (Georgia, Indiana and Tennessee) had the same rate.
The Top Five States
The five states with the lowest December 2022 estimated NSA construction unemployment rates were:
- Colorado, 1.2%
- Tennessee, 2%
- Utah, 2.1%
- Florida, 2.2%
- Nebraska, 2.6%
With the exception of Utah, all of these states posted their lowest December estimated NSA construction unemployment rate on record. Utah had its third lowest rate, behind 2021’s 1.7% and 2015’s 2%.
The Bottom Five States
The states with the highest December 2022 estimated NSA construction unemployment rates were:
- Illinois, 7.1%
- Ohio, 7.4%
- Minnesota, 7.6%
- Wyoming, 10.4%
- Alaska, 13.3%
Alaska had its second lowest December estimated construction unemployment rate behind 2020’s 11.8% rate and the third largest year-over-year decline in its rate among the states (tied with Pennsylvania), behind Rhode Island and Hawaii, down 2.3% from December 2021. The other four states each had their third lowest December unemployment rate on record.
For more information, visit ABC's website.
