NFPA 70E Tip
May 16, 2019
How to stay up to date with the latest safety standard revisions
If you’ve been using NFPA 70E for several years, great. But are you using the latest revision? The 2018 revision contains both minor and major changes, some of which were made after intense discussions among the members of the Technical Committee on Electrical Safety in the Workplace. New inputs from OSHA and other concerned parties also shaped the decisions that resulted in the current revision.
One of the primary goals was to make it simpler to use in the field. The information on PPE selection, for example, has changed with that goal in mind.
If you have an older revision, don’t simply toss it when you get the new revision. While the new revision has text shading to show what has changed since the previous revision, it doesn’t have the handwritten notes in the margins that your previous version probably has. It doesn’t have a way of reaching out into your procedures and training materials to highlight what should change there, either.
It’s helpful to use your older revision as a guide to understanding the “why” of how things are currently done. You can answer the question, “Why are we doing it this way, when the new revision shows to do it that way?” The answer can help you transition more smoothly to conforming with the new revision, especially if you also think about why the new revision would have the new rule (change) that you’re looking at instead of the old rule you were following.
