Aerial work platform inspections might not be exciting, but these routine tasks collect critical information that helps operators, mechanics, and fleet managers keep equipment in service and ensure jobs are completed safely. Daily, weekly, monthly, and annual inspections act together to ensure all components of an aerial work platform are in working order while also providing peace of mind to owners whose businesses depend on these important assets.
Annual inspection
Among the criteria set for aerial work platforms by the American National Standards Institute (ANSI) is the mandatory annual inspection of these units. Only experienced mechanics can perform these wide-ranging inspections, which cover structural components such as outriggers, booms, turrets, and substructures as well as safety items like decal legibility and placement. Authorized equipment distributors often provide inspection services.
Annual inspection records must be retained for five years. If you’re considering purchasing an aerial work platform, it’s wise to also research the unit’s annual inspection history. Be sure to consider the safe storage of inspection records. In the event of an accident, authorities (including OSHA) will seek these inspection records and may levy penalties if the records cannot be located.
For additional safety tips and more information on ANSI standards affecting aerial work platforms, refer to the OSHA A92.2 fact sheet at https://www.osha.gov/Publications/aerial-lifts-factsheet.pdf.
Periodic aerial work platform inspections
Aerial work platform manufacturers typically provide logbooks for daily, weekly, and monthly inspections.
Daily logs cover items such as engine and hydraulic oil levels, parking brakes, lights, safety features, boom and turret function, and platform controls. Weekly logs assess items like battery function, winch brake operation and pump, PTO and driveline function. Monthly logs include assessing cylinders and valves, checking the machine’s welds and pins, placement of control, safety and capacity placards and assessing boom wear pad fasteners and rollers.
The logs also include space for mechanics to document problems, prescribe solutions, and record repairs. An advantage to keeping diligent daily, weekly, and monthly logs is that the logs make for a great reference tool during the preparation for and completion of a required annual inspection.
Be proactive
Since these logbooks combine to cover a wide range of data points over time, the diligence pays off in many ways:
• Constant logging allows operators to become more familiar with the safe operation and maintenance of their equipment.
• Routine daily and weekly checks of equipment lets mechanics “see around corners” by identifying possible problems before they become serious issues.
• Identifying and promptly resolving issues based on periodic log entries increases the probability that equipment will easily pass annual inspections.
• This process is not only required by ANSI, but also helps to minimize risks inherent in aerial lift operation.
Making inspections a routine part of your fleet maintenance program is critical to keeping aerial work platforms in productive service, limiting repair and replacement costs, and reducing the risk of failures that can cause serious property damage or personal injury. Don’t put your assets or workers at risk. Take the time to perform these critical inspections.
Cheleen is a HiReach Specialist who has been with Elliott Equipment Co., Omaha, Neb., for more than 10 years. He can be reached at [email protected]. Note: This article was originally published on the Elliott Equipment Co. learning center.
