The fact a confined entry permit is posted doesn’t mean you’re safe in the confined space. Let’s take a closer look at some situations to avoid.
- Assuming you’re covered by the posted permit. It might be someone else’s permit, and it is specific to where they’ll be and what they’ll be doing in the space. Always make sure you have your own permit (or it covers the crew you are on).
- Assuming the permit is correct and will protect you. People make mistakes, and miscommunication happens. Question and verify every item on the permit. If something doesn’t add up, don’t enter; resolve the discrepancy first.
- Not questioning things you don’t understand. We often don’t want to look foolish by asking questions when nobody else is asking them. When it comes to safety, asking questions makes you look smart and in control.
- Not challenging a permit restriction that will interferes with your work. A common “solution” to this is to just work around the requirement. That defeats the purpose of the permit. Instead, find a way to change the work, permit, or the environment so the permit isn’t violated.
