Cable tie installation tool The Ty-Rap cable tie installation tool is designed to ease user fatigue with features including an adjustable grip span and an anti-recoil cut-off mechanism that reduces vibration when installing cable ties. The tool also ...
The Ty-Rap cable tie installation tool is designed to ease user fatigue with features including an adjustable grip span and an anti-recoil cut-off mechanism that reduces vibration when installing cable ties. The tool also includes variable tension settings, a high-low handle force mode, and interchangeable tool heads that cover the 18-lb to 120-lb range of cable ties. Its 360° rotating nose eliminates the need to twist the tool when the cable tie orientation is rotated.
