Conduit Marking Device is a Knockout
March 1, 2007
After working as a commercial electrician/foreman for more than 11 years, Brent Galbreth, president of Deviser, Inc., Winchester, Calif., knew there had to be an easier way to mark electrical enclosures for conduit entry. Like many electrical contractors, he found the task of measuring each conduit, transferring the measurements to the enclosure, and getting everything to fit exactly right both arduous
After working as a commercial electrician/foreman for more than 11 years, Brent Galbreth, president of Deviser, Inc., Winchester, Calif., knew there had to be an easier way to mark electrical enclosures for conduit entry. Like many electrical contractors, he found the task of measuring each conduit, transferring the measurements to the enclosure, and getting everything to fit exactly right both arduous and time consuming. Thus, the concept of the KO Stamp was born.
“The idea for the KO Stamp came to me almost five years ago,” says Galbreth, the tool's designer and developer. “After spending many nights working on ways to solve the problem, I finally had the general concept of how I wanted the tool to work. Then, I set out to find a way to develop a product that would work effectively.”
Comprised of a vinyl insert, a vulcanized rubber stamp with center point, and inkpad, the KO Stamp is a marking device that helps installers find the center point of conduits in an electrical enclosure. According to the company, the tool allows users to eliminate measurements and cut layout time by as much as 98%, compared to the traditional method.
Intended for electrical contractors and electricians, Galbreth's initial design started out as a threaded cap with a rubber stamp on top, but he soon found that adjusting every stamp in the raceway took too long. Instead, he designed the KO Stamp to fit inside the conduit. A major issue, however, was that each type of conduit (e.g., rigid, EMT, and PVC) has a different inner diameter. After some trial and error, Galbreth finally found the exact size for each stamp that would fit in any type of conduit.
“The benefit of the KO stamp fitting inside the conduit is you can adjust the stamps above the tallest conduit in the raceway,” says Galbreth. “As your enclosure makes contact with each stamp, the stamps will slide down the conduit until it makes contact with all the stamps in the raceway.”
Drawing upon his experience as an electrician, Galbreth tested the product on layouts in the field. “When I created the KO Stamp, my co-workers at A&R Electric would test the product for me,” he says. “Now, I think the only way they know how to lay out an enclosure is with the KO Stamp.”
According to Galbreth, in addition to saving time, the KO Stamp saves money by helping eliminate certain conduit layout mistakes made in the field. “Sometimes, electricians reverse the layout like a mirrored image — they don't account for the bolt holes on the back of the enclosure, which stick out ¼ to ⅜ of an inch, etc. In most cases, mistakes like those will result in scrapping the enclosure and starting over.”
Using the KO Stamp involves a straightforward three-step process: Insert the stamps into the conduit, ink the stamps, and place the electrical enclosure on the stamps and apply even pressure. The tool gives electricians the center point, conduit size, and diametric lines passing through center to align the knockout punch score lines for a precise hole. In addition, it is reusable, rugged, and works on underground applications, overhead, and sideways. The ink used to mark the conduit is dye based and takes 10 to 15 minutes to dry, which allows time for electricians to set the enclosure. This also gives you enough time to wipe the ink off in the event you make a mistake.
“On average, with the traditional way, I could layout an enclosure with 25 to 50 conduits in about 1 to 2 hours,” notes Galbreth. “Now, with KO Stamp, I can average 2 to 4 minutes for the same layouts.”
Chick Weldt agrees. An electrician who performs both commercial and industrial work for Reddy Electric Co., Xenia, Ohio, Weldt first heard about the KO Stamp through his general foreman, who recommended he try it. “I thought it looked like a great time-saving tool, and time is money,” he says. “It saves about 40% of a standard installation. I use it for placing wire ways and panel tubs. It solves the problem of exact placement of conduits — especially coming through the floor. Also, it gives a really nice finished product.”
Introduced in April 2006, the KO Stamp is Deviser, Inc.'s first product offering. According to the company, no similar product exists on today's market. Priced at $48.65, the KO Stamp starter kit includes 27 stamps (in sizes ranging from ½-inch to 4 inches in diameter to fit all standard conduits) as well as an inkpad. Contractors can also customize the kit to meet their specific needs. For more information, visit www.KO-Stamp.com.
Stefanie Kure | Content Producer - EC&M
Stefanie Kure is the senior associate editor of EC&M magazine. She holds a Bachelor of Arts degree from the University of Kansas and has more than 20 years of experience in the B2B magazine industry. In addition to EC&M, Stefanie has worked on Transmission & Distribution World magazine, Broadcast Engineering magazine, and Power Electronics Technology magazine.
