ID 250839216 © Valiantsin Suprunovich | Dreamstime.com
6734e13d74a9f31a63b78dcd Dreamstime Xxl 250839216
Code Q&A: NEC Requirement for Power and Control Tray Cable
Nov. 14, 2024
Courtesy of www.MikeHolt.com. Based on the 2023 NEC.
Question: Which of following statements about power and control tray cable is incorrect?
a) It may be used in a raceway.
b) It may be used for power, lighting, or control circuits.
c) It may be installed where it will be exposed to physical damage.
d) It may be used in cable trays in hazardous locations where the conditions of maintenance and supervision ensure that only qualified persons will service the installation.
See answer below.
Answer: c) It may be installed where it will be exposed to physical damage.
Section 336.12(1) lists, "installed where it will be exposed to physical damage" as a use that is not permitted for Type TC tray cable.
Mike Holt
Latest from Quizzes
ID 20924167 © Monika3stepsahead | Dreamstime.com
dreamstime_xl_20924167
ID 8209371 © Indiloo | Dreamstime.com
dreamstime_xl_8209371
ID 136399449 © Stefano Carnevali | Dreamstime.com
dreamstime_xl_136399449
