© Yattaa8 | Dreamstime.com
Dreamstime Xxl 116445194 64650ca60d6e1
Code Quiz: Receptacles in Dwelling Unit Garages
May 18, 2023
Based on the 2023 NEC.
Question: True or false? All receptacles in dwelling unit garages must be supplied from 20A branch circuits.
See answer below.
Answer: False
Explanation: In the 2023 NEC, text was added to Sec. 210.11(C)(4) to make it clear that receptacles installed in addition to those required by Sec. 210.52(G)(1) can be fed from 15A branch circuits. Only those receptacles required by Sec. 210.52(G)(1) are required to be on 20A branch circuits.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 118474400 © Welcomia | Dreamstime.com
dreamstime_118474400
ID 6510117 © Sallyjogary | Dreamstime.com
dreamstime_xl_6510117
ID 148267107 © Mkopka | Dreamstime.com
January 2025 code iq
