Code Quiz: Receptacles Inside a Bathroom Exhaust Fan
April 6, 2023
Based on the 2023 NEC.
Question: True or false? A receptacle, factory installed, inside a bathroom exhaust fan requires GFCI protection.
See answer below.
Answer: False
Explanation: A new exception was added to Sec. 210.8(A) in the 2023 code to make it clear that a factory installed receptacle that is not readily accessible and located inside a bathroom exhaust fan does not require GFCI protection.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
