Code Quiz: Overcoming Rock Challenges When Installing Ground Rods
Nov. 3, 2022
Based on the 2020 NEC.
Question: What are the options for installing a ground rod if you cannot drive it due to encountering rock?
See answer below.
Answer: Drive it at an angle not exceeding 45 degrees from vertical. If rock is still encountered at an angle up to 45 degrees, the rod can be laid horizontally in a trench at least 30 inches deep.
Explanation: See Sec.250.53(A)(4) in the 2020 National Electrical Code (NEC).
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
