© Chernetskaya | Dreamstime.com
Illustration 228881071 Chernetskaya Dreamstime 632220812cb29
Code Quiz: Service Entrance Conductor Requirements
Sept. 15, 2022
Based on the 2020 NEC.
Question: True or False? Service entrance conductors entering a building are limited to 10 ft in length before connecting to the service disconnect.
See answer below.
Answer: False
Explanation: Section 230.70(A)(1) of the 2020 NEC requires the service disconnect to be located "nearest the point of entrance of the service conductors." No maximum length is specified. Since nearest the point of entry can be subject to the interpretation of the AHJ some jurisdictions will specify the length of conductor permitted and 10 ft is a common interpretation for many AHJs.
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 331482540 © Bekir Ugur | Dreamstime.com
dreamstime_xxl_331482540
ID 331513454 © Petr Goskov | Dreamstime.com
dreamstime_xxl_331513454
ID 321335940 © Weerapat Wattanapichayakul | Dreamstime.com
dreamstime_xxl_321335940
