Based on the 2020 NEC.
Question: Can service equipment contain exposed uninsulated live parts?
See answer below.
Answer: No
Explanation: Section 230.62(C) requires barriers to be provided so that no live parts can be contacted while servicing load side terminations. This means there should be no exposed live parts when the service disconnect is in the open position.
John Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind., and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
