ID 36311653 © Adonis1969 | Dreamstime.com
Dreamstime M 36311653 5e986038e7332
Code Quiz: Physical Protection of the GEC
April 16, 2020
Put your Code knowledge to the test.
Based on the 2020 NEC.
Question: Can PVC conduit be used as protection against physical damage for a grounding electrode conductor (GEC)?
See the answer below.
Answer: Yes
Explanation: Section 250.64(B) of the 2020 National Electrical Code (NEC) allows for the use of Schedule 80 PVC conduit for physical protection of grounding electrode conductors (GECs). This is a change from the 2017 edition of the NEC, which allowed both Schedule 40 and Schedule 80 to be used.
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 367200439 © Contributor Asia | Dreamstime.com
dreamstime_xl_367200439
ID 81540477 © Wavebreakmedia Ltd | Dreamstime.com
dreamstime_xl_81540477
ID 376312510 © Евгений Полишко | Dreamstime.com
dreamstime_xl_376312510
