Code Quiz: Transformer Disconnecting Means
Oct. 4, 2012
Fill in the blanks with the appropriate answer. When installing a transformer (such as a 75kVA unit), the disconnecting means for this piece of equipment shall be _________, and the location of the disconnecting means shall be ______ marked on the transformer. A. approved / properly B. lockable / field C. suitable / suitability D. lockable / factory Answer: B
B. lockable / field
Answer: B
As noted in 450.14 of the 2011 NEC, "Transformers, other than Class 2 or Class 3 transformers, shall have a disconnecting means located within sight of the transformer or in a remote location. Where located in a remote location, the disconnecting means shall be lockable, and the location shall be field marked on the transformers."
Latest from Quizzes
ID 342999012 © Maksstock78 | Dreamstime.com
dreamstime_xxl_342999012
ID 12988709 © Marc Torrell Faro | Dreamstime.com
dreamstime_xxl_12988709
ID 47007877 © Brian Toth | Dreamstime.com
EC&M Quiz Nov/Dec Quiz: Holiday Lighting and the NEC
