Code Q&A: Requirements for Securing and Supporting Raceways and Cable Assemblies
Courtesy of www.MikeHolt.com
Q. What are the requirements for securing and supporting raceways and cable assemblies?
See answer below.
A. Raceway and cable assemblies must be secured and supported per the requirements in Sec. 300.11.
(A) Secured in Place. Raceways, cable assemblies, and enclosures must be securely fastened in place.
(B) Wiring Systems Installed Above Suspended Ceilings. Ceiling-support wires or the ceiling grid are not permitted to support raceways or cables. Independent support wires secured at both ends can be used to support raceways or cables.
(C) Raceways Used for Support. Raceways are not permitted to support other wiring methods, except as follows:
(2) Class 2 and 3 Circuits. Class 2 and 3 cables can be supported by the raceway that supplies power to the equipment controlled by the Class 2 or 3 circuits.
(D) Cables Not Used as Means of Support. Cables are not permitted to support other wiring methods.
These materials are provided to us by Mike Holt Enterprises in Leesburg, Fla. To view Code training materials offered by this company, visit www.mikeholt.com/code.
