Courtesy of www.MikeHolt.com
Based on the 2020 NEC.
Q. What is the Code rule for marking disconnects for signs in commercial buildings?
See answer below.
A. A disconnecting means for a sign, outline lighting system, or controller must be marked to identify the sign, outline lighting system, or controller it controls. [Sec. 600.5(B)]
Exception: An external disconnecting means that is mounted on the sign body, sign enclosure, sign pole, or controller is not required to identify the sign or outline lighting system it controls.
These materials are provided to us by Mike Holt Enterprises in Leesburg, Fla. To view Code training materials offered by this company, visit www.mikeholt.com/code.
