Figure 430 1 02 62168f42d659b
Code Q&A: Types of Motor Controllers
Feb. 23, 2022
Test your knowledge of the NEC.
Courtesy of www.MikeHolt.com.
Based on the 2020 NEC.
Q. ­What is the NEC definition of a motor controller?
See answer below.
A. The NEC defines a “controller” as any switch or device used to start and stop a motor by making and breaking the motor circuit current [Sec. 430.2 Definitions]. 
A controller can be a horsepower-rated switch, snap switch, or circuit breaker. A pushbutton that operates an electromechanical relay is not a controller because it does not meet the controller rating requirements of Sec. 430.83. Devices such as start-stop stations and pressure switches are control devices, not motor controllers.
Mike Holt
