422 11 E3 01 5f3e80ab73b60
Code Q&A: Overcurrent Protection Requirements for Appliance Circuits
Aug. 20, 2020
Test your knowledge of the NEC.
Q. What are the NEC branch circuit overcurrent protection requirements for appliance circuits?
See answer below.
A. (A) Branch Circuits.
Branch-circuit conductors must have overcurrent protection in accordance with Sec. 240.4, and the overcurrent protection device rating must not exceed the rating marked on the appliance [Sec. 422.11].
(E) Nonmotor Appliances.
The appliance overcurrent protection device must:
(1) Not exceed the rating marked on the appliance.
(2) Not exceed 20A if the overcurrent protection device rating isn’t marked, and the appliance is rated 13.30A or less, or
(3) Not exceed 150% of the appliance rated current if the overcurrent protection device rating isn’t marked, and the appliance is rated over 13.30A. Where 150% of the appliance rating doesn’t correspond to a standard overcurrent protection device ampere rating listed in Sec. 240.6(A), the next higher standard rating is permitted.
Example Problem: What’s the maximum size overcurrent protection device for a 4,500W, 240V water heater?
Solution: Protection Size = 4,500W ÷ 240V = 18.75A × 150% = 28A
Answer: 28A doesn’t correspond to a standard ampere rating, so use 30A which is the next size up [Sec. 240.6(A)].
These materials are provided to us by Mike Holt Enterprises in Leesburg, Fla. To view Code training materials offered by this company, visit www.mikeholt.com/code
Mike Holt
Latest from Q&A
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 8209371 © Indiloo | Dreamstime.com
dreamstime_xl_8209371
ID 57245818 © Mrchan | Dreamstime.com
dreamstime_xl_57245818
