Code Q&A: 25-Ft Tap Rule
April 23, 2015
NEC rules on the 25-ft tape rules
Q. Please explain the 25-ft tap rules in the NEC?
A. Feeder tap conductors up to 25 ft long are permitted without overcurrent protection at the tap location if the tap conductors comply with the following [240.21(B)(2)] (see Figure):
• The ampacity of the tap conductors must not be less than one-third the rating of the overcurrent device that protects the feeder [240.21(B)(2)(1)].
• The tap conductors terminate in an overcurrent device rated no more than the tap conductor ampacity in accordance with 310.15 [240.21(B)(2)(2)].
Mike Holt
Latest from Q&A
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 8209371 © Indiloo | Dreamstime.com
dreamstime_xl_8209371
ID 57245818 © Mrchan | Dreamstime.com
dreamstime_xl_57245818
