Code Q&A
Oct. 9, 2008
Our utility requires a nonfused disconnect upstream of the meter and service disconnect for certain services. Is this legal?
Q. Our utility requires a nonfused disconnect upstream of the meter and service disconnect for certain services. Is this legal?
A. Yes, meter disconnect switches that have a short-circuit current rating (SCCR) equal to or more than the available short-circuit current can be installed ahead of the service disconnecting means. A meter disconnect switch must be capable of interrupting the load served [230.82(3)]. Electric utilities often require a meter disconnect switch for 277/480V services to enhance safety for utility personnel when they install or remove a meter.
Mike Holt
