Code Q&A
Sept. 8, 2011
Q. How do I size the conductors for an arc welder?
A. The supply conductors for arc welders must have an ampacity not less than the welder nameplate rating. If the nameplate rating isn't available, the supply conductors must have an ampacity not less than the rated primary current as adjusted by the multiplier in Table 630.11(A), based on the duty cycle of the welder.
Let's work an example problem to help hit this point home.
A non-motor/generator arc welder has a primary current rating of 40A with a duty cycle of 50%.
Calculated Load = Primary Rating x Multiplier [Table 630.11(A)]
Calculated Load = 40A x 0.71 = 28.40A
Therefore, the branch-circuit conductor for the welder must not be sized less than 30A. As per Table 310.15(B)(16), a 10 AWG conductor has an ampacity of 35A at 75ºC.
Mike Holt
Latest from Q&A
ID 8209371 © Indiloo | Dreamstime.com
dreamstime_xl_8209371
ID 57245818 © Mrchan | Dreamstime.com
dreamstime_xl_57245818
ID 360841573 © Kenishirotie | Dreamstime.com
dreamstime_xl_360841573
