© Photoking | Dreamstime.com
Dreamstime Xxl 131219195 650b042aa7ec4
TIA Issued for 2023 NEC Regarding Sec. 408.6
Sept. 20, 2023
TIA 1699 was issued on August 25, 2023, with an effective date of September 14, 2023.
Pursuant to Section 5 of the NFPA Regulations Governing the Development of NFPA Standards, the National Fire Protection Association has issued the following Tentative Interim Amendment to NFPA 70®, National Electrical Code®, 2023 edition. The TIA was processed by Code-Making Panel 9 and the Correlating Committee on National Electrical Code, and was issued by the Standards Council on August 25, 2023, with an effective date of September 14, 2023.
1. Revise 408.6 to read as follows:
408.6 Short-Circuit Current Rating. Switchboards, switchgear, and panelboards shall have a short-circuit current rating not less than the available fault current. In other than one- and two-family dwelling units, the available fault current and the date the calculation was performed shall be field marked on the enclosure at the point of supply. The marking shall be of sufficient durability to withstand the environment involved. comply with 110.21(B)(3).
Note: A TIA is tentative because it has not been processed through the entire standards development process. It is interim because it is effective only between editions of the standard. A TIA automatically becomes a public input of the proponent for the next edition of the standard; as such, it then is subject to all of the procedures of the standards-making process.
