© Siarhei Dzmitryienka | Dreamstime.com
Chapter 7, Special Conditions is arranged into logical groupings.
- One or more of the first 20 article numbers (700 to 720) may apply if you have on-site power generation.
- Articles 720 and 725 apply respectively to circuits that have special voltage or power limitations, with 725 at 13 pages being by far the larger of the two.
- Articles 727 and 728 actually apply to special cables (instrumentation tray and fire-resistive).
- Article 750 applies to energy management systems.
- Article 760 applies to fire alarm systems. It is unlikely you will use this chapter unless you are a qualified fire alarm systems engineer or technician. In which case, you will also use NFPA 72 and NFPA 101.
- The final article, 770, provides the requirements for fiber optic cables and is one of the largest Chapter 7 articles. Light is not electricity, so why is this here? One of the several reasons is these cables are run through fire barriers, inside plenums, and through occupied spaces. They must not appreciably contribute to the spread of combustion.
