© Nataliia Dvukhimenna | Dreamstime.com
Dreamstime M 15195478 606c7d3dc371c
Chapter 9 of the NEC — Part 6
April 6, 2021
Use Table 9 to determine electrical reactance values.
Electrical reactance is a measure of the opposition to current flow from inductance or capacitance.
Inductive and capacitive components store energy. With resistance, the energy is continuously dissipated as heat. With reactance, that stored energy is returned to the circuit and the result includes phase changes. Knowing the reactance of a coil or other device (or even an entire circuit) is important in some applications. For example, determining what phase changes to expect can help you select the right transformer.
If you start a motor, the inductive reactance is initially low but rapidly increases. This is why we have inrush current. We also have inrush current in non-resistive lighting technologies (e.g., fluorescent).
The total reactance of a circuit is the difference between its inductive reactance and its capacitive reactance. You may recall the vector diagrams from your electrical theory classes if you haven’t been using them on the job (yet).
With alternating current (AC), even the conductors have reactance. The amount varies with the conductor size and the raceway containing the conductors. Need to know the values? See Table 9 in Chapter 9.
