NEC Class and Division Basics
March 6, 2018
Know your hazardous location fundamentals
Hazardous locations are classified based on the properties of the combustibles in the location. A location isn’t necessarily a whole building; it can be a room or even an open area within a building.
The NEC has two classification systems:
  1. Class and Division, as laid out in Art. 500.
  2. Zone, as laid out in Art. 505 and Art.506 (alternate method).
A location is:
  • Class I if flammable or combustible vapors or gases are present in sufficient quantities to produce explosive or ignitable mixtures.
  • Class II if combustible dust presents the threat.
  • Class III if ignitable fibers or combustible flyings present the threat.
  • Class I is the most stringent, Class III the least.
In Class I and Class II, it’s:
  • Division 1 if the threat is present during ordinary conditions.
  • Division 2 if the threat is present during abnormal conditions.
In Class III, it’s:
  • Division 1 where easily ignitible fibers/flyings are handled, manufactured, or use.
  • Division 2 where easily ignitible fibers/flyings are stored or handled other than in the process of manufacture.
  • Division 1 is more stringent than Division 2.
