WAS_/iStock/Thinkstock
Suppose you have an outbuilding that doesn’t have its own service. Instead, it’s served by a branch circuit or feeder (on the load side of a service disconnect). This is a common arrangement. For example, an industrial facility may have a guard shack or pump house supplied this way.
One of the rules for this arrangement is only one branch circuit or feeder can supply that building [225.30]. But you can use additional branch circuits or feeders to supply any of the following:
- Fire pumps.
- Emergency systems.
- Legally required standby systems.
- Optional standby systems.
- Parallel power production systems.
- Systems that connect multiple sources.
The AHJ can grant special permission for:
- Multiple occupant buildings that lack the space for supply equipment accessible to all occupants.
- Structure large enough to make more than one supply necessary.
And you may use additional branch circuits or feeders if:
- The capacity requirements exceed 2000A (at 1,000V or less).
- You need to supply different voltages, frequencies, or phases. Or you need to supply for different uses (e.g., control outside lighting from multiple locations).
- You have documented safe switching procedures.
