Ecmweb Com Sites Ecmweb com Files Uploads 2014 10 Appleton
Welding Receptacles or Power Receptacles?
Oct. 29, 2014
The requirement for one is very different from the other.
Photo courtesy of Appleton Group LLC, Emerson Industrial Automation
In petrochemical plants and refineries, there are usually many 480VAC, 3-phase receptacles scattered throughout the facility. Many times, the owner wants these receptacles to be used only for maintenance turnarounds, so the receptacles are used only for power packs to provide 120VAC, 1-phase power for small hand tools, such as drills, grinders, etc. However, sometimes these receptacles are used for welders too.
When designing industrial electrical systems that include 480V receptacles, it’s important to know how these receptacles will be used. If that fact is unknown, it’s better to err on the conservative side and install a dedicated fused disconnect/breaker ahead of the receptacle to comply with the requirements of NEC Art. 630 [Electric Welders]. Doing so will ensure that whether the receptacles are used as power receptacles for miscellaneous loads or welders, NEC requirements for the protection of these receptacles will have been met — and you won’t have safety issues.
All major manufacturers have combination fused disconnect/receptacles for this purpose. The photo illustrates a typical explosionproof disconnect/receptacle combination that can be used for either power receptacles or welders.
© 2014 Fluor Corporation. All Rights Reserved.
Eddie Guidry | Senior Fellow
Eddie Guidry is a senior fellow with Fluor Enterprises, Inc., Sugar Land, Texas. He is highly skilled in electrical and control systems for industrial construction, design, and engineering (both domestic and abroad). The majority of Eddie’s 38 years of experience includes upstream and downstream portions of petrochemical plants and refineries. He is also heavily experienced in water and wastewater treatment facilities. Eddie is very active in the development of U.S. national (ANSI) and international codes and standards, and has been a principal member of the National Fire Protection Association (NFPA) National Electrical Code (NEC) committee since 1999 and NFPA’s National Advisory Committee on Electrical Safety Research since 2008. Eddie, who has also developed and conducted many electrical courses and seminars over the years, currently holds the corporate Master Electrician license for Fluor Corporation in the State of Texas and is also an ICC/IAEI certified electrical inspector.
