© Redwall | Dreamstime.com
Dreamstime M 12926340 611bc3b5313d5
A Simple Way to Reduce PM Backlog
Aug. 17, 2021
Keep only the tasks needed to prevent the most time-consuming repairs.
If your PM backlog is spiraling out of control and you can’t get more resources, how can you close the gap? If you have sufficient history on completed repairs, then you could perform an analysis to determine two things:
  1. Where the PM is insufficient to prevent specific time-consuming breakdowns.
  2. Where a given PM task helps prevent a specific type of breakdown, but such a breakdown has never occurred.
The problem with the first item is that you don’t have resources to put there unless you take them from elsewhere. The problem with the second item is that you risk having even more breakdowns.
The issue is time, and that’s what you need to save. The following method must exclude critical equipment because it accounts only for maintenance time. It does not account for lost revenue, or issues of environment or safety.
For non-critical equipment, identify all failure modes. Then, assess the repair time for each failure. Temporarily (at least) keep only those PM tasks that are needed to prevent the three most time-consuming repairs.
