© Auremar | Dreamstime.com
Dreamstime M 160939137 60f619efd5b65
Manufacturer’s Recommendations
July 20, 2021
Use common sense when maintaining equipment per the manufacturer.
Do you maintain equipment per the manufacturer’s recommendations? That would seem to make sense, especially if that equipment is under warranty. However, you may want to consider some other things:
  • The typical manufacturer is not a maintenance expert. Likely, someone at the company pulled the maintenance specs from an older product. For example, it says to change the air intake filter on the control cabinet quarterly. But if you use differential pressure sensing to know the condition of the filter, you will change it when needed — no dirty filter means no needless change.
  • NFPA 70E does not say to follow the manufacturer’s maintenance instructions. It says to do that or to follow industry consensus standards [205.3].
  • Time-based work is guesswork while condition-based work uses measurement. The more you can replace time-based work with condition-based work, the lower your costs and the higher your reliability. The trick is to establish the correct measurements to give an accurate condition assessment.
  • Automate where possible. For example, the manufacturer recommends measuring the supply voltage during each afternoon. Anything critical should be automatically monitored.
