wildpixel/iStock/Thinkstock
time bomb
Temporary Repairs
Sept. 3, 2019
Four ways to keep temporary repairs from becoming permanent
Temporary repairs, sometimes referred to using the famous brand name of an adhesive bandage product, are a fact of life in production facilities. Temporary repairs are typically made for business-driven reasons, such as delivery pressures and resource utilization (e.g., not having operators idle).
The repairs may involve using bypass jumpers, the wrong type fuse or breaker, a custom-machined (“jury rigged”) part, or some other means. In a Midwestern plastics plant, a failed E-stop was replaced with a normal stop switch until a new E-stop could be obtained later that day.
The main problem with temporary repairs is they tend to become permanent. To prevent this, you need a special process for them. It should include:
  • A form that Operations must sign before the temporary repair will be made. They agree to provide downtime as soon as you have what you need to affect the correct repair.
  • Local notice (e.g., a sticker) identifying equipment with a temporary repair.
  • CMMS work order for the proper repair. It should provide an alert periodically (e.g., twice a day) until the repair is completed. The response to the alert is to check the progress on obtaining the parts or whatever else is needed.
  • A means of ordering the needed parts/services/materials on an expedited basis.
Latest from Maintenance, Repair & Operations
ID 79734135 © Tashatuvango | Dreamstime.com
A folder with a tab that says 'Equipment Maintenance' rests on top of a keyboard.
ID 346742527 © Contributor Asia | Dreamstime.com
Pink blocks that spell 'quiz' against a light green background next to a white alarm clock.
A finger presses a green key on a keyboard that says 'NEC National Electrical Code'
