Just because equipment is deenergized and locked/tagged out doesn’t mean it’s safe to work on. Suppose Fred responds to a trouble call; a conveyor drive motor failed. Some other hazards include:
- Falling hazard number one. While Fred is disconnecting the motor, product falls on him from the conveyor.
Solution: Operators need to clear the equipment of in-process material. - Falling hazard number two. To do the work, Fred stands on the conveyor. But it’s not mechanically locked, and it shifts as he steps on it causing Fred to fall.
Solution: Lock the conveyor, or (better) use a ladder rather than stand on equipment. - Tripping hazard. Fred stumbles over parts bins left in front of the equipment, doing a face-plant that requires a trip to the hospital.
Solution: Operators clear the work area. - Slipping hazard. Fred pulls new wiring, using cable lube. He also greases the motor. He slips and breaks his wrist.
Solution: Put down a tarp or paper to collect lubricant; clean messes as you go.
