Type NM cable shall not be used _____.
a) in other than dwelling units
b) in the void of masonry block not subject to excessive moisture
c) for exposed work
d) embedded in poured cement, concrete, or aggregate
The correct answer is: d) embedded in poured cement, concrete or aggregate
Article 334 covers the use, installation, and construction specifications of nonmetallic-sheathed cable. Installation rules are outlined in Part II of this Article. More specifically, as noted in Sec. 334.12(A)(9), "Types NM, NMC, and NMS cables shall not be embedded in poured cement, concrete, or aggregate."
