Space Separation Between Resistors and Reactors
Nov. 3, 2014
Article 470 covers the installation of separate resistors and reactors on electrical circuits.
For installations of resistors and reactors, a thermal barrier shall be required if the space between them and any combustible material is less than _____ .
a) 2 in.
b) 3 in.
c) 6 in.
d) 12 in.
The correct answer is: d) 12 in.
Article 470 covers the installation of separate resistors and reactors on electrical circuits. As noted in Sec. 470.3, "A thermal barrier shall be required if the space between the resistors and reactors and any combustible material is less than 12 in."
Mike Holt
