Approved Uses of Type MI Cable
July 2, 2014
Article 332 covers the use, installation, and construction specifications for mineral-insulated, metal-sheathed, Type MI cable.
Which of the following statements about Type MI cable is correct?
a) It may be used in any hazardous (classified) location where permitted by other Articles of the Code.
b) It shall not be permitted for branch circuits.
c) It shall be securely supported at intervals not exceeding 10 ft.
d) none of the above
The correct answer is: a) It may be used in any hazardous (classified) location where permitted by other Articles of the Code.
Article 332 covers the use, installation, and construction specifications for mineral-insulated, metal-sheathed, Type MI cable. Section 332.10 lists the 11 uses permitted for this type of cable. As noted in 332.10(7), Type MI cable shall be permitted "in hazardous (classified) locations where specifically permitted by other Articles in this Code."
