Code Quiz: Equipment Operating at Over 1,000V – Fuses
Jan. 24, 2019
Test your knowledge of the National Electrical Code requirements for fuses over 1,000V
For power fuses installed in equipment operating at over 1,000V, their maximum voltage rating shall not be less than the maximum _______ voltage. Fuses having a minimum recommended operating voltage shall not be applied below this voltage.
A) circuit
B) symmetrical
C) asymmetrical
D) none of the above
See the answer below.
Answer: A
Article 490 covers the general requirements for equipment operating at more than 1,000V, nominal. As specifically outlined in Sec. 490.21(B)(1)(3), “The maximum voltage rating of power fuses shall not be less than the maximum circuit voltage. Fuses having a minimum recommended operating voltage shall not be applied below this voltage.”
Steven Owen
Strut Comparison Chart
NECA Manual of Labor Rates Chart
See how Champion Fiberglass compares to PVC, GRC and PVC-coated steel in installation.
