Photo 300005643 © Edgars Sermulis | Dreamstime.com
dreamstime_xxl_300005643
Code Quiz: Feeder Conductor Requirements
May 2, 2024
Based on the 2023 NEC.
Question: True or false? Feeder conductors are permitted to be installed in the same raceway as service conductors.
See answer below.
Answer: False.
Explanation: The answer to this question is found in Sec. 230.7. The NEC states, "Circuit conductors other than service conductors shall not be installed in the same raceway, cable, handhole enclosure, or underground box as the service conductors."
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino | Senior Design Engineer
Chapter 9 of the NEC — Part 5
