Code Quiz: Disconnecting Means for Low-Voltage Suspended Ceiling Power Distribution Systems
Nov. 8, 2018
Check your knowledge of low-voltage distribution systems in suspended ceilings
A disconnecting means for the Class 2 supply to the power grid system for low-voltage suspended ceiling power distribution systems shall be located as to be __________ and ___________ of the Class 2 power source for servicing or maintenance of the grid system.
A) readily accessible / lockable
B) accessible / within sight
C) convenient / part
D) none of the above
See the answer below.
Answer: B
Article 393 of the 2017 NEC covers the installation of low-voltage suspended ceiling power distribution systems. As specifically noted in Sec. 393.21(A), “A disconnecting means for the Class 2 supply to the power grid system for low-voltage suspended ceiling power distribution systems shall be located as to be accessible and within sight of the Class 2 power source for servicing or maintenance of the grid system.”
Steven Owen
Strut Comparison Chart
Strut Corrosion Guide
