© Zhanna Hapanovich | Dreamstime.com
question answer blocks in front of dart board
Code Q&A: NEC Requirements for RMC
Sept. 28, 2023
Test your knowledge of the NEC.
Courtesy of www.MikeHolt.com
Q.  What are the conditions RMC can be used and installed?
See answer below.
A.  The condition where RMC can be used and installed are found in Sec. 344.10.
(A) Atmospheric Conditions and Occupancies.
(1) RMC is permitted in all atmospheric conditions and occupancies.
(B) Corrosive Environments.
(1) RMC fittings, elbows, and couplings can be installed in concrete, in direct contact with the Earth, or in areas subject to severe corrosive influences if approved for the condition. 
(D) Wet Locations. Support fittings (such as screws, straps, and so forth) installed in a wet location must be made of corrosion-resistant material or protected by corrosion-resistant coatings in accordance with Sec. 300.6.
(E) Severe Physical Damage. RMC is permitted where subject to severe physical damage.
Mike Holt
Strut Comparison Chart
Strut Corrosion Guide
