Ground Testing Techniques
Prior to about 15 years ago, the basic methodology for ground testing remained fundamentally unchanged since it was originally devised in the early 20th century. The end-user would use a test instrument and probes to first inject a current into the earth between a test electrode and a remote probe, measure the voltage drop caused by the soil to a designated point, and then use Ohm's Law to calculate
Discuss this Article 2
Bob Allsbrook (not verified)
on Aug 30, 2012
We are doing a project for the USAF on the 7th floor of a building. We have a 1/0 ground ring around a space and all metal bonded to the ring. the 1/0 ring connects to a ground bar in the electrical room with 3/0 down to first floor service entrance ground. This space has a special metallic ceiling tile for grounding and copper shielding over ever light in the space and all is bonded to the 1/0 ring above the ceiling. I am searching for the proper procedure to test the resistance on this system.
Thank you.
robert duncan
on Jan 16, 2013
Contact RO Associates
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Jan. 27, 2010
video
Electrical Construction and Maintenance
Arlington Cable Entrance Plates
Arlington’s new REVERSIBLE entrance plate not only protects cable but delivers good looks and installation versatility. Use it facing in or out. Non-rusting paintable plastic....More
Newsletter Signup
Connect With Us
