Nec Wwh 0120 Pr 5e20e27e03680
What’s Wrong Here? This Neutral Bus Has Me Seeing Double
Jan. 16, 2020
Can you spot the Code violation(s)?
How well do you know the Code? Think you can spot violations the original installer either ignored or couldn’t identify? Here’s your chance to moonlight as an electrical inspector and second-guess someone else’s work from the safety of your living room or office. Can you identify the specific Code violation(s) in this photo? Note: Submitted comments must include specific references from the 2017 NEC.
Hint: This neutral bus has me seeing double.
November Winners
Our three winners this month were: Wayne Cellio, a reader from Leland, N.C.; Kyle Haberkorn with Dynamic Electric, Inc. in Alsip, Ill.; and Sean D. Klein with Chevron in Covington, La. Each of these readers correctly cited violations in this photo.
I received lots of submissions from our readers this month correctly citing the NEC violations in this photo. Unfortunately, our contest rules only allow me to select three random winners. Keep reading and sending in your submissions for a chance to win!
For raceways containing insulated conductors, Sec. 300.4(G) requires 4 AWG or larger conductors to be protected by an identified insulating fitting, providing a smoothly rounded surface, such as a plastic bushing, where these conductors enter a cabinet, box, enclosure, or raceway. No such fitting was used on this raceway, and the result is evident by the nicked and damaged conductor insulation. Also, the missing wireway cover is a violation of Sec. 376.100(D), which requires covers to be securely fastened to the wireway. The missing cover results in an incomplete enclosure and a violation of the construction requirements of Sec. 376.100(B).
‘Tell Them What They’ve Won...’
Using the 2017 NEC, correctly identify the Code violation(s) in this month’s photo — in 200 words or less — and you could win an Arlington Industries FLBT4400SS countertop box kit, which includes a stainless steel trap door cover and a 20A decorator-style, tamper-resistant receptacle. E-mail your response, including your name and mailing address, to [email protected], and Russ will select three winners (excluding manufacturers and prior winners) at random from the correct submissions. Note that submissions without an address will not be eligible to win.
Russ LeBlanc | Owner
