NFPA 70E: Annex Marks the Spot, Part 13
Do you have a procedure for working near overhead electrical systems?
April 18, 2025
3 min read
Coming into contact with an overhead power line is a preventable safety incident. When it’s not prevented, the consequences are usually fatal. Informative Annex N provides an example of an industrial procedure for working around overhead electrical lines and equipment.
The example procedure is preceded by a short introduction [N.1] that covers important principles and concepts. An important principle is you should always assume the lines are hot and operating at over 1,000V. An important concept is that as the voltage increases, so also do the minimum working distances and the potential for arc-over.
Six requirements are stated in N.2. One of these is that employees be informed of the hazards and cautions when working near overhead lines. Another is that a spotter be assigned when someone is operating equipment near overhead lines. The spotter is responsible for observing safe working clearances around all overhead lines and directing the operator accordingly.
All employees and contractors must follow this procedure [N.3]. Because most company and contractor employees are not qualified to determine the system voltage level, a qualified person shall be called to determine voltages and clearances, and then take appropriate action to make the work zone safe.
The meat of Annex N is in N.4, which is divided into six subsections:
N.4.1, general requirements. This consists of four paragraphs. Notably, all electrical contact incidents, including “near misses” shall be reported to the local health and safety specialist.
N.4.2, look up and live flags. This subsection provides a few requirements for this life-saving safety item. These flags are used to indicate whether lifts, cranes, etc. are in use or have been returned to the “stowed or cradled” position.
N.4.3, high risk tasks. This addresses heavy mobile equipment, aerial lifts (and cranes and boom devices), and tree work.
N.4.4, underground electrical lines and equipment. This briefly addresses the requirement that you contact the local USA Dig service (call 811 or go online) and what to do if there isn’t one.
N.4.5, vehicles whose loads exceed 4.25 meters (14 feet) in height. This has six requirements. One of them is that an electrician, electrical construction representative, or qualified electrical contractor should check the intended route to the next location before actually taking that route.
N.4.6. emergency response. This enumerates eleven steps to take if an overhead power line falls or is contacted. The first is to keep everyone at least 10 feet away. The second one is to use flagging to warn people and help protect them from fallen or low wires.
